Replace headlight bulb, easiest way?
  Renault Clio 2011
Hey,
My mothers headlight bulb broke on the passenger side (left side when you're infront of the car) she asked me to replace it because she coulnd't do it herself.
I'm just wondering what would be the easiest way of replacing the headlight bulb, would it be going trough the "normal" way where the motor is or is it easier removing the front bumper?
EDIT: The car is a Renault Clio 2011
Advikaz
Remove the accoustic valve fittings & move it out the way. Take off battery cover & fuse cover & that'll give you a fair bit more room to operate.
Then it's just a case of removing the rubber cover from the back of the lamp & pulling the wire out of the rear of the bulb.
