Replaced faulty pre-cat o2 sensor - now worse MPG!
Just wondering if this is a common thing....
At the weekend I had my pre-cat o2 sensor replaced, I was averaging about 33MPG prior to this, this week, doing the same run, im averaging 28MPG!
Does the computer need to 'learn' that a new sensor is in or have I bought a faulty sensor?! Its a Bosch one by the way.
thanks,
Dave
  M3 Touring
did you fit a new sensor?
you should 'generally' be seeing better MPG from a new lambda, why did you change it.. was it causing problems?
