Replacing 172 Seats.. how hard is it?
  2002 Clio Sport 172
Just bought a spanking condition set of clio 172 seats for my phase 2 just wondering how hard is it to change the front seats? the airbag procedure worries me more than anything.. e.g does it have to be set up by Renault again to work properly? or do i just flip a switch, then undo a few bolts and hey presto?!
MRBILLYUK
  FF Jeden Osiem Dwa
I'm guessing that you would have to disconnect the battery for about 30 mins before you fit the new seats and plug in the new connector ,then reconnect the battery afterwards, i might be wrong , if i am somebody correct me .
  2002 Clio Sport 172
Sorry yeah was aware of having to disconnect battery so airbag loses its charge.. thanks Guys.. if anyone else can give me a defo "Yes" to this procedure. i guess i can get to work
thanks again Gem
Simple, as said disconnect the battery about 30 mins beforehand then unplug the looms under the seats remove the rubber bungs from the floor pan and undo the nuts holding the seats in under the car.
