Replacing coolant??
Morning all,
I'm going to drain my gfs coolant and replace, i'm looking for some guidance.
What hose do u disconnect to drain the fluids?
What type of collant to you repace it with Blue/Red etc?
Clio Authentique 1.2 2001.
Thanks guys:dapprove:
  mk1 clio hybrid
there should be a "tap" on one of the bottom corners of the radiator just turn that and it will drain the coolant and replace it with new coolant which you could get from a renault garage. not sure how much coolant it will take to fill the system but if u get the coolant from a garage you could always ask. hope this helps
  Megane dci 130
Remove the bottom radiator hose to drain. There wont be a tap on the mk2's.
Then refill with coolant and water and bleed the system via the valve cap thats on the thermostat housing. Road test, make sure hot air out of vents and re check level.
Coolant change..... DONE!
