Replacing lower Ball Joint??
M
mattlear23
Hi Guys, just wondered how difficult it is to replace the lower ball joint? Got it already, just wondered what I need in order to get it all done, like tools and stuff? Thanks, Matt
Sash
  A Yellow One
Piece of peeeee!
Ball joint splitter or large screwdriver?
  RB 182 Cup
I just replaced mine a month or so back. Just a word of warning, one of my pinch bolts seized in place solid, I tried brute force, wd40 and heat, but all failed. I'd then made such a mess of the bolt trying to hit it out with a 4lb hammer that I couldn't get the nut back on. Car now stuck outside my home address with the suspension undone and needed to be taken to a garage.
You'll also need to fully support the chassis leg and brake disc as it will fully extend when you undo the lower ball joint. You'll never be able to just push it back up yourself, you'll need a jack or similar. There might be a trick, but I couldn't find it.
