Replacing Mounts?
Car  Clio 172
Thought while im at it i might aswell order everything
so ive order
1x upper mount
1x upper gearbox mount
1xlower gearbox mount
My question is do i need 2 upper engine mounts? I.e one for either side?
Also do I need 2 of the others or just 1?
Cheers Ben
There's 4 mounts total only 1 of each required.
Upper Engine Mount on drivers side
Upper Gearbox Mount bolts into battery tray
Lower Gearbox Mount just under battery tray
Lower engine mount (often known as the dogbone mount) underneath and towards back of engine
Dogbone mount is often the one causing the most problems with knocking so worth replacing if not already done.
Thanks Ben your a star. Think im going o order the bottom one as the middle doesnt seem to be the twisted type and its over a tenner cheaper than Ktec!
