replacing sub frame
might as well repace the bolts also the wishbones and ARB bushes.
Nope not engine out its not that dificult only rust and stuck bolts are the iddue. You ned to jack the car up undo 4 bolts holding it on to the car a few more for maounes wisnbones etc and drop it out.
Ahh, cheers Edde. I have a suspicion that mine is bent as the space above the drivers front wheel and its opposite corner are more than the others by 3/4s of an inch and the handling feels the same?
Check your springs havn't broken sounds more likly.
To bend a subframe you need to crash realy you can tell if it was broken that much.
