Replacing the aerial base
Just supposing I'd been dumb enough to not remove my aerial before going through a car wash....and just supposing the car wash ripped it off including the screw thread bit inside the black plastic aerial base.....how would I replace that?>!?!?!
i replaced mine y-day, dead easy.
Under the little plastic circle as stated, and theres also 2 slidding clips to the rear of the roof lining, unclip those too.
May be worth taking your 3rd seatbelt thing off as well, as that will restrict alot of movement/space beyond the roof lining.
Take these 3 off, feed ur hand in over the top of the roof liningand undo the bolt (21mm? iirc), and then lift it off from the top!
10 min job, if that
To the OP,
They are about £15 new from renault for a mk2 phase 2 car, assuming you don't have factory sat nav - if you do, it's £80.00
- you don't say what clio you have though, what mk, phase etc.
