I'll just put an advert on here, someones bound to have all the bits.@DomP182 Just Checked for squib and where I bought it from don't have any now.
Thanks again for your help, would I also need a brake switch? I've read a few guides with contradictory info@DomP182 Just Checked for squib and where I bought it from don't have any now.
But the part number I listed is the one I searched for. I would say yes regarding the esp.
It's not possible on the ph1 due to the cable throttle.debating installing cruise in my ph1 172 but I'm not sure how it would work with the cable throttle :/
I did some brief googling the other nightIt's not possible on the ph1 due to the cable throttle.
Yes but your not going to be able to run a system like that using the standard setup of Renault dials, buttons etc
Oh yeah it's all good there, just was reading and someone mentioned a small loom or connectorHave you tried the ESP/cruise switch and not got the SET and lights?
Yeah I've connected everything up at the pedal end and panel, just need to pop the wheel off to do that bitI didn't buy another loom, sorry not 100% sure on the wheel as I have the OMP wheel now.
Do you have the loom for the clutch switch?
There is a guide on here to remove and replace the squib, I will see if I can find it.Yeah I've connected everything up at the pedal end and panel, just need to pop the wheel off to do that bit
Just out of curiosity did you need an additional brake switch?.
Yeah replacement stalk, I'm not sure whether the problem was there in recent times as I've not used lights in ages but what I would say is that the stalk is less smooth than the old one so maybe its faulty.Was that a replacement stalk as well and If so did you have the same issue with the old stalk?
