Retrofit Cruise Control in Clio MK3 - Anyone has done it?
  Clio 3 1.5DCi 2011
Hello,
I have a Clio 3 phase 2 1.5 Dci, Dynamique S
I would like to install Cruise Control on my car.
As far as the mechanic told me my car already has a pre-instalation (some wiring harness) for the Cruise control.
As anyone retrofited Cruise Control on a Clio?
Any info or tips on how to do this and proceed?
Thank you so much
Martin_172
If it's the same as the process on a MK2 then you will need the dashboard switch, the steering squib, wheel/airbag with buttons, clutch and brake pedal switches then may or may not need to configure it in Clip depending on how the car is setup (on the MK2 RS cars don't need config but non RS cars did)
  Clio 3 1.5DCi 2011
Thank you so much my friend, that's a huge help
Also some people talk about the need for an "Airbag Ribbon wiring" I can't find info on that, do you know what it is?
Thank you so much
Matt Cup
  Leon Cupra, 172 Cup
Thank you so much
That’s what Rsrowe quoted above fella.
  Clio 3 1.5DCi 2011
Thank you Martin,
I thought the Ribbon, at least by written descriptions, would be a ribbon wiring with multiple wires, I don't see ribbon looking wiring in the Squib.
But thank you, I will probably order that part
  Clio 3 1.5DCi 2011
Does anyone know if I buy the Complete Steering wheel (the cruise control model) if it already comes with the Squib installed as part of the complete steering wheel?
This is the one:
