rev counter out of range
installed a rev counter with shift light only problem is that when my original rev counter reads for example 1000 rpm the rev counter reads 600rpm approx 40% less any guesses what it could be
and a big thank you to 16v_jon for explaining how to connect the tacho up no one else!!!!!
mandeep
mandeep
You've probably got it connected/switched to the 6 cylinder set up instead of the 4 cylinder (or visa-versa)!
Hope this helps.
Wiltsteve
the green cable from the tacho which was the rpm siginal was connected to the pin one on the coilpack plug going into the coilpack. pin 1, 2 and 3 have cables pin 4 is empty. . .
mandeep
sorry mate, I'd love to help but I can't. Thought I'd ask about management, because a few systems will allow you to run a tacho off that
would anyone think using a better cable from the coil to the green cable which holds the siginal to the tacho could help a more accurate rpm reading
