rev limit
its a combination of everything you mention in your first post! they can take 8k rpm on a stock engine, but it won't last, 7800rpm is pushing it in terms of reliability, if you want to rev it that high fit ARP rod bolts and use GOOD oil (5W50 is what i'd suggest, help keep the pressure up)
valve springs.
crank (balanced), conrods & pistons.
That would give you a few hundred more revs to play with, I think? (But I'm probably wrong)
