Reverse Light Headache
  Clio 172 2.0 16V RSport
Guys Help!!
I have a 172 53 plate with no reverse lights.
I have checked the bulbs = all working fine
I have checked the fuses = all fine
I have put the wipers on the front and selected reverse = auto rear wiper works fine
Argh!! Frustrating....
Anybody got any ideas....
I am being told that if the rear wiper works when you select reverse, it cannot be the switch. Is that correct??
Please Help :mad:
Daz
Check the connection pins, they get a bit rusted / oxidated. I also had to give mine a wiggle and a spot of wd40
the best way 2 test it , is to remove the connector and bridge the 2 wires together and the revers lights should come on then you know for def its a switch if they don't come on the is a fault in the wiring , you checked all the fuses?
