right foot on the floor but no movement?
I just went out for luch, went to pull away when car was in gear and it wouldnt move, right foot was on the floor and revs were sitting @ 500rpm and there was nop noise from the engine, had to take it out of gear then go again, has happened a couple of times, why is it doing this?
either be the throttle pendometer(electric motor) or the throttle pedal, check in the footwell there is a thin electrical connector , connected to the top of the pedal if this is connected then you may have to have it pluged in to see what is causing it
so it should be plugged in right?
essssssssssssexxxx..! But i'm scottish by blood so the Essex doesnt explain the thickness.. im good with my car, just not clio engines!
As Al said, if the ECU has changed its mode, why dont you get one of those chip thingys you plug into the ECU and can modify it? Then you can make it a teeny bit faster too! lol
might just do that, am going for a 172 conversion but and going to try and make the quickest 1.2 track car to date with this, then if this engine blows up i can get the 172 engine quicker lol
hm essex hey, im only in kent, also have familly in scotland, uncla has a huge farm in aberdeen,
you going to the bluewater meet?
cliokhunt said:
My DCi idles at 800rpm....
Regarding the problem, you seem to let on it doesn't always do it ???? Or is it actually not drivable ?
it just does it sometimes, it is still dirvalble, normally perfictly well
Sounds like something computer related...
Like when you go into reverse it seems to numb the throttle. Get it into Renault, not much else you can do.
yep does that in reverse too,
warrenty is up, will the rip my arse open? :rolleyes:
Not much you can do, if you want it fixed, get it fixed.
(P.S. It's meant to do that in reverse, only thing it achieves is making donuts take a second longer to get going..)
So if you press the pedal nothing happens? Right? What age is your Clio - mk2 ph1? mk2 ph2? etc.
