Right Xenon headlamp
Car  Black Mk2 172
Only seems to work when it wants to? sometimes switching lights on and off seems to work , other times not/ could it be a loose connection somewhere? Cars a Mk2 172 btw
theres an earth wire inside near the bulb it comes loose that will be or a loose connector , worst case could be the starter or ballast
Most Comomon Fault Is The Ballast Unit To Get Water In And Blow Mate, Just Change The Ballast.!!!!!!!!!!!!!!!!!!!!11
my 182 was doing the same thing it turned out it was a faulty alternator, dealer fitted new alternator and all has been fine , ask the dealer to check it for you m8 .
brian
