Road Angel re-radiating aerial.
NickM5c
  BMW M5 Audi TT
The Road Angel in my 172 takes forever to get a signal which i am presuming is being caused by the U.V screen. I am looking to purchase the optional re-radiating aerial and i wanted to know if anyone who has the aerial where they positioned it inside the car and is it easy to fit? Thanks.
  ICE'dberg MK2 172
If you put it inside the car then you are back to square one!! bodywork/screen shielding it.
stuck mine on the roof...now I have a signal.
easy to fit...just hide the wires and plugs directly in the ciggy socket with a piggy back connector so the angel fits in it too.
Try Radar UK...mine cost £60....ouch!
NickM5c
  BMW M5 Audi TT
Cheers. My Angel is already hard wired into the ignition circuit so does the aerial run off the angel or does it need its own power supply?Did you have to drill a hole through the body work to get it on the roof and if so where abouts did you place it? I must admit i do not really want to go down that road though.
Tom
  EV (s)
You could find out how much the gps ariel from renault is (the one used for the sat nav) but fitting it would be hard. (roof lining needs to be removed)
But the end result would be very good.
NickM5c
  BMW M5 Audi TT
A good idea but it sounds like a lot of jip for something that i will eventually take out the car anyway.
NickM5c
  BMW M5 Audi TT
Cursed U.V screens!!!!! My girlfrind has a 1.6 Dynamique and the thing works perfectly in her car, not that she is having it anyway of course.
Tom
  EV (s)
what about the window at the base? thats unprotected.
(but youve tried that)
  2012 WRX Waggon
I popped the remote antenna for my Snooper on the rear parcel shelf, once its got a lock seems OK.
The "comfort glass" in the windscreen is a pain in the ass!
NickM5c
  BMW M5 Audi TT
Will the wire for the aerial reach the parcel shelf? This sounds like the easiest option.
  ICE'dberg MK2 172
Its quite long but not sure if its THAT long tho
my wire is tucked under the outside rubberseal around the screen and then enters under the door seal into the cabin....the only restrictive bit is the internal aerial that needs to be close to the angel...hence its a re-radiating aerial...LOL!!
