rocker cover gasket?
Car  titanium 182
mine is leaking - can i get this fixed under warranty as it is a design fault not a wear and tear problem? Also my accelerator pedal squeaks! And I've got a knocking noise sounds like its coming from the drivers side- I've had one of the top mounts replaced and i thought it was the offside that was done!?
ANy ideas?
Yes you can. Mine is in as we speak having the rocker/cam cover gasket replaced under warranty. They've taken 3 days about it, but that's another story! :rolleyes:
ooooh mine is having a head gasket and rocker cover gasket as we speke...how strange;)
speke, isnt that a place in liverpool???;)
Mines booked in for exactly the same on the 14th June, getting all the loose ends tied up before the warrenty runs out end of June.....'spose I should prepare myself for self-destruction from then on! :S
Brian said:
Mines booked in for exactly the same on the 14th June, getting all the loose ends tied up before the warrenty rounds out end of June.....'spose I should prepare myself for self-destruction from then on! :S
you do get a new cambelt with it.... so not all bad:)
