B Barryd Aug 7, 2003 #2 Much faster spin up over one with a 270 or 360 deg bearing. Much less lag Supposed to be more reliable. VERY EXPENSIVE compared to conventional bearing turbos.
C Chris_H Aug 7, 2003 #3 hmmmmmmmmmmmmmm anyway Roller bearing turbos comes with 360 degree thrust bearing, or they should do. Anyway, benifits are increased response and reduced spool up time. Reliabilty, well in a way they are, as a plain bearing turbo especially one thats got a crap oil feed with groove the shaft in no time.
B Blue Mule Aug 7, 2003 #4 And construction wise, whats the main difference between rollerbearing and normal turbo?
C Chris_H Aug 7, 2003 #7 not usually, you can get then though. Like ceramic wheel bearings etc you usually need to ask.
J jabba Car Corsa 2.0 16v baby Aug 7, 2003 #8 ceramics will pop with pissy amounts of boost thou so dont bother unless its a low boosting unit your after.
C Chris_H Aug 7, 2003 #9 how so? Better tell the rally boys this new info! And tell them that their wheelbearings wont last either.
J jabba Car Corsa 2.0 16v baby Aug 7, 2003 #10 standard ceramics like ones on supras etc wont take the same amounts of boost as the normal equivilant. the blades are lighter but no as strong so i hear from various sources. ps rally technology is obviously gonna do better isnt it! ill give them a bell anyway thou.
