rotten eggs smell
J
Jim NM
What's the deal with the rotten eggs smell in the car. I have had a look at the cat and the exhaust and there are no obvious leaks (not blowing)
has anyone any other ideas what could be causing this?
When I turn off the climate control, no smells, but this is hardly ideal!
Or is it that the cat has reached the end of it's useful life.
I am tempted to put on a decat pipe but emissions law/MOT is making me have second thoughts.
Thanks for any comments
  172 cup
rotton eggs hmm gearbox box oil comes to mind. Check all around gearbox especially where the n/s drive shaft attaches as there prone to leaking
  RS RIP
smells like a cat ;)
when driving my other car, wih cat , i get this whenever i push it hard for a while
  Not a poxy Renault
Check your battery, they can degrade and give off a rotten egg smelling gas, make sure the sides of it are not bowed and there are no leaks. Batteries are Very dangerous when they are like this.
  Ultra 197 ex 172 Cup
your probably got a cylinder / spark plug problem, and too much petrol going into the cat, which will make it stink, my car did this when runnign on 3 cylinders as ht lead broke.
  RB 182 & Lotus Evora
i thought this was the aircon issue found quite common....could be wrong mind you but there is a odoriser spray you can use to clean it out
