Just thought i'd resurrect this thread.
My modded 2001 172 (RS tuning remap, matched inlet and throttle body, yozasportt cat back exhaust, noise valve removed from airbox) has developed this lumpy idle problem when warm, it doesn't try to cut out, it just stutters like it has a momentary misfire.
This problem only started after a cambelt service (belt, tensioner, & dephaser as a precaution). I noticed it the moment I got in the car and thus it was taken straight back to be looked at. The timing was initially out by a fraction so this was rectified and is now spot on (at the same time the new type crank pulley was fitted), its been treble checked. There was a bad connection on the throttle sensor, but this has now been fixed too. It has also had another set of fresh spark plugs and there are no fault codes in the ECU.
The car is run on normal unleaded most of the time so i've ruled this out as it was fine before. I have read that this problem does appear after a belt change, has anyone found out why? Or fixed it?
Its starting to cause arguements now as i'm refusing to pay the bill until its fixed, my arguement is that it wasn't doing it beforehand.
