Roughly how much camber will you get as standard with coilovers? - Help please
A bit of advice chaps..
Im fitting my coilovers later which are FK Konigsports and wondering how much camber they can give as standard? Im going to get it aligned but until i do should i max them out? I've read that some of the poverty spec coilovers dont even give as much as standard..
I plan to get camber bolts and a setup so only a temp measure for a week.
Any advice appreciated.
Without camber bolts, you can't adjust, so it should give near on standard camber. Unless the dampers are slotted obviously- if so, just match up left and right as close as possible.As soon as you fit camber bolts it gives you the adjustment option.
Think fk have the upper hole slotted, so built in adjustment. Without this camber would change with height, so there's no answer either way
Yeah they are sloted so can be adjusted and i am going to try and get them even (to eye). So not even an idea? I cant see them giving me anything like -3 degree's would they?
It sounds ghetto, but get a small spirit level (even one on the iphone) on the face of the hub. That will give you a rough idea of the camber on the wheel. Either that, or bolt it on loosely, then place the wheel on and inspect.. Make sure both are the same, even if you are running serious negative.
Good thinking batman. I'll give that a whirl..haha
