rs grill
Car  BG 182 FF
fitting an rs grill 2moro hopefully. How easy is it? And what do i have to do and what tools may be required? thank you
Nick:)
2 person job to make it easy.
lift up bonnet
reach inside
press back the clips that hold the grille in...around 8 clips in all. work your way round from one side to the other is the easiest i found.
the grille pushes in to release once the clips are pushed back
fit RS grill much in the opposite way
pretty simple
15 min job.
easyer then that.
Lift up bonnet
Pull the 2 plugs out that secure it at the top
Bang each grill back (give it a thump) and both will pop back
Should just pull off
hmm I swapped mine over recently when I fitted a new front bumper, I would have thought the above method would risk breaking the clips, I would take the bumper off if you want to be extra careful only takes 10 mins to get it off anyway.
