RS Tuner Diagnostic Troubble Codes
Car  TrackCar & F30 330d
I delete them a few weeks ago but they have returned.
DF0189 Flywheel Tooth Memory
DF0093/DF0102 O2 Sensor Rear Memory
DF0135 Brake Information Fault Memory
N/A Electronic Throttle Control Limits Acquired (Not a fault) Present
Does anyone know what has caused any of these.
I have a Decat so i think the O2 sensor rear is because of that.
I have bucket seats so my airbag light is on because of them.
Any help would be great
Chris
Normal
Happens often, usually a faulty or not properly adjusted brake switch
Not good, indicates an intermittent problem with your flywheel sensor.
In your case, normal
Please note; that disconnecting a sensor during ignition ON will store a fault code as well.
Normal
This could be why my cruse control doesnt work. I did adjust the switch the other day. Could have fixed it? if no i'l buy a new one.
:( Is the sensor easy / cheap to replace? I could do it if i could get to it!
The car very rarely doesnt start first time.
I get this all the time. How do I adjust it? I've got a cup if that makes any difference?
The one to keep an eye on is the
The rest is of lesser importance.
The DF189 code can be looked up in Dialogys for repair instructions..
