give me an email adress to send it , the forums doesn`t support uploading .
If you got the OEM rst , you don`t need the OEM .cal , because the .cal is in the .rst
the 172 rst is different than the 182 , also the 172 has a different ECU .On the 182 the ecu is ems3134 , and on the 172 the ecu is sirius34 . They both have the same pinout .I`ve sent you the .cal for a 182 ,altough I own a 172 ph2 .Don`t try and put a 172 cal in the 182 cal or viceversa .Also don`t try and write a 172 rst on a 182 ,the position of the maps adresses is slightly different and like I said , not the same ECU .I hope it works .
You`re welcom .
