RS Tuning Box
Car  BG 182 & 225 T
Does anyone know where I can get a hold of a rs tuning box, or if anyone is selling one?
And how exactly do they work with programming them then actually installing it?
cheers!
First of all, check int he wanted section, they are always poping up there.
secondly, you don't 'install' the RSTuner, its a device that is used to communicate with your cars ECU. You basically connect it via an OBD2 port (which is under the ash tray in your car). The RSTuner is also connected to a laptop which is used to control what is happening. When you buy the maps from fastchip.nl (Henk), then you use this setup to transfer it to your existing ECU. Once complete, you disconnect it and sell it on if your never going to use it again.
People Help me with Purchase Rs Tuner Kit ! From Fastchip.nl . They have 2 in stock . But i dont` see my VIN VF1CB220F32434085 in purchase select .
I didn't think you needed the VIN if you are buying new, only if your unlocking a used one? If you do, then its on your VIN plate and should be on your registration documents.
Rs.jpg Which one ? :)
I have ordered one on Monday :)
Does everything come with the kit or do you need to get the map off the site ?
Alan
Hi
I just have couple of question about the fast chip
i have clio 3 Rs200 with vin number VF1CRRDF, and I don't see anything about that plus my car is LHD, and after I buy it can i add more modification later on and and do remapping again?
regards
hamad
