The RS2 is recommended to be run with the Upgrade engine mounts as the inlet sits close to the slam panel and 'could' make contact if your mounts were worn.
You 'can' run it with standard mounts but only really recommended if they are new / nearly new so the engine doesn't Rock under acceleration.
