RSTuner. Fault Codes help
Got an RS Tuner and remapped it with the performance map the other day.
When I initially plugged it in it threw up a couple of codes, just wondering if anyone could shed some light on them?
I know the bottom one isn't a fault but what does it mean.
Also I have Buckets and Decat, so my EML and SERV/Airbag Light are on, shouldn't it have thrown codes up for these too?
ECM | DF0135 | Brake Information Fault
ECM | N/A | Electronic Throttle Control Limits Acquired (Not a fault)
James both codes are from the engine control module ECM and not relevant.
To read and erase the airbag codes you need our airbag module. With it you can also enable/disable airbags.
