RSTuner Problem.. Write verification failed...
Car  AB182, Audi A5 3.0
Im having trouble flashing the RON98 overrun map on my car, the RON98 map works all ok, but he overrun map give a write verification error and sets my ECU to 0000 0000 (and car wont start).
The files im using are:
Clio 182 EL 1921 8200_7804_Decat_Overrun_RON98_0411
and
Clio 182 8200_7804_F4R738_RON98_1110
Anyone know whats going wrong? Or does anyone have a compatible RON98-OR map they could pm me in case mine is broken?
Many Thanks.
Sounds like you need a 'custom' overrun map.
Custom? What needs to be customised? is it something I can do?
I assume you backed up your original ECU before doing this? :S
​I hope so...
Yes I backed up, but I restored, the Clio 182 8200_7804_F4R738_RON98_1110 map anyway which works ok.
I'd be sending Henk an email...
Done this already, sent it to info@fastchip.nl, hope that's the correct one? Wasn't sure what to send him though as the maps weren't bought via the site (second hand).
How did you get it working in the end? I know you've managed to get an overrun map working on your car?
Mine just bricks the ECU when you try to put the standard map on the car.
