Rubbing sound MK1 phase 2
It's coming from the drivers front wheel.
Initially when you drive the car there is no noise. After 20 miles it's starts (i.e. something is getting hot)
When you turn right on full lock there is a metal on metal scrapping sound when it's hot or warm.
However, there are no symptoms....
Wheel appears tight and bearings were replaced only 6 months ago
No vibration or anything else through the steering; grip levels are as they should be.
No vibration under breaking or accelerating and the noise continues even when on the brakes with clutch engaged.
Help!! What could it be? Think it might be a driveshaft but surely you would feel this under power?
Suggestions appreciated as I'm going to have to strip the car down to find it....
