running low on oil
has anyone had to top their oil up a few times in the first year or so of having a new clio. its only a 1.2 16v and ive done nearly 16k but ive had to put 6 litres of oil in as the oil light comes on every few 3 or 4k its not leaking and its not buring oil. any ideas?
  (ex-2.0 Hybrid)CorradoVR6
well it must be either using or leaking oil somewhere otherwise it wouldnt be using that much oil. Get it booked in.
  172 cup,s2 rs turbo
anything under 1 litre per about 700 miles is within renault tolerences.oil consumption will decrease as the engine wears in.
Am I right in thinking you shouldnt wait for an oil light to come on in a car, because that means the level is dangerously low and nearing engine blow up time! (If you checked the level on the dipstick once the light comes on I bet the level is off the end of the dipstick). You should check it regularly instead.
