Running rich and lumpy idle
Car  clio sport 182 ff
hi guys just bought a 182 with an injector fault p0303, moved the injector to cylinder 4 and got p0304, I changed the injector today and the misfire has gone! but iv still got a lumpy idle and a strong smell of fuel, the car cam with a full k-tec system with decat, so I don't know if this will affect it? any ideas guys? did a live read on the diagnosic and the values were way out.
Gonna take the O2 sensor off and give it a clean as I don't know how long it's been over fueling before I bought it, got a seal for the inlet manifold on order just in case there's an air leak between the rocker cover and manifold, hopefully this will sort it?
It's a map sensor that's used on these cars so won't be the inlet to head gasket as it's working with pressure and not flow.
In my experience, O2 sensors usually need changed rather than cleaned but worth a try.
The O2 sensor was changed in February 2014 so it's only 2 year old, would the faulty injector ruin it? It's still switching just at stupid values?
