RUST!
  1.2 Dynamique 16v
I took my rear reg. plate off the other day to get rid of the broken surround. Unfortunately I found a spot of rust. :dead: Its no bigger than a finger nail but I want to treat it or something and then cover with a larger plate.
Comments would be appreciated.
Thanks in advance :rasp:
Ok, that sounds easy enough. I'll have a go at it this weekend!
Will I need any other protection following the application of rust stopper?
sand back and around the area so you know the rust hasn't spread then apply the rust remedy treatment stuff,
i would then add a bit of primer to it
and finally just spray top coat
