My idea was to 'simply' move the engine to the back, but 4wd would be interesting, but i dont think im 100% confident in exicuting it. which renault has an electronoic rack, didnt know there was one!? what would be the benfit of having the ABS unit tell the rack to speed to go?
Im thinking if i can weld together a Jig which i can bolt to the floor, with both subframes attached to (with the correct wheelbase etc) then lower the shell onto the jig and bolt the front subframe on, and mark out where the subframe needs to be mounted, weld in new subrame mounts, attach the rear subframe. Then cut out the suspenion turrets and engine mount points (basicly the whole inner engine bay), from the donor, again calulate the distances, width and hight etc, weld them to the shell and strenghten where apropriate aplicable, wled some sort of rollcage for rigidity. I understand it isnt all as simple as i have writen and there will be alot of details so sort, but the way i see it is if i understand just whats got to be done step by step, take my time and get as much information then i cant go far wrong. Agian cliosport is a massive archive for information, like yourself and other people on hear who are always happy to answer and ask questions. This sounding a bit far fetches or quite pheasable?
