Safe to drive with a faulty injector?
  M3 Touring
When you say faulty... What is wrong with it? Normally if you have a damaged / down injector the car will go into limp mode and be pretty much undrivable.
  clio 172 phase 2
The diag machine said open circuit cylinder 4 injection valve . Mines not gone into limp mode or anything jus runs a little more lumpy and use alot more fuel .
  Mk4 Mondeo Estate
If its using a lot more fuel the injector could be dribbling which can wash the oil from the cylinder and you can end up with a lot of damage to that cylinder
  Clio
on the otherhand run lean..... and burn a whole in your piston, or valves..... :( very uncool
So no, not a good idea. Dont do it
