Salt on clio
Go out and wash the salt off your car. Splash a bucket on the allloys and one under each arch. If you dont think that salt is that bad, consider that they cant put salt on runways because it damages the planes. IT WILL EAT YOUR CAR.
I wouldnt do that the water may freeze on the car causing more problems than paint trouble.
Paint on aircraft is thinner I think, also the engine intakes are supsetable to ingress damage so some little bits of stone will cause some massive damage plus increase operating costs.
Im going to wash mine tomorrow but all the mud on it has probably protected the paint (builders using the area round my office as a soil dumping ground.
EDD
  Elise/VX220/R26
how about f**k that by the time its rusting Ill be doing donuts in my vx220 turbo ;)
seriously tho its wheels that salt really f**ks up. Mine have been getting a thorough wash every week
You dont want to put anything mildly corrosive near an aircraft for safty reasons...common sense really. Jet aircraft dont rely on traction like cars as they accelerate with thrust and slow down with reverse thrust so a mildy icy runway doesnt matter. I work for an airline, I know i wouldnt want salt anywher near Airbus 319/320s
Salts not good for any aircraft. Planes use there brakes though. No idea about Airbus but Boeing use ABS for sure.
Which arline do you work for if you dont mind me asking? Do you work with any of the bigger planes?
I think the main reason fo not salting the runway is the fact it gets into the controls water alone gets everywhere under flaps. Get griyt in piping can be dangerous especialy at high speed as damage could be caused.
EDD
EDD
Lets just say I dont work for a no frills or charter carrier. Our engineering boys deal with A319/320, Boeing 737/756/767/777 as well as numerous 747-400s . Need I say more ;)
  Ph1
In the last big freeze I washed my car in the morning [wasnt freezing then]and by 3pm the doors had frozen shut!!!!
EDD
Oh and I forgot Avro RJ-100 s ;)
KDF
  Audi TT Stronic
That and the fact that the tyres on planes dont really do anything, once the plane is landing on the runway its going in a straight line.. traction or no traction..
Plus its the engines that do 90% of the braking on the ground anyway, hence the reason the reverse thrust flaps flip up on the engine when you hit the runway..
Depends on the landing the brakes are very strong (legal requirment to be able to stop on them alone) but pilots usually use reverse thrusters to slow as brake cost to be replaced.
I saw the Beluga land with all its brakes on maxed out and it realy does slow it down with them. Normal stopping is without brakes and its much longer.
EDD
  VW Potato
please, is there a distinction between grit on the roads and salt. I thought the councils gritted with grit, not salt? (could be wrong about this though). Erm, maybe grit has salt in it?
g
