Hi, I've been a member for a couple of years and have made use of this forum a lot, so thank you! First time I'm posting..
I had to travel out during storm Christoph last week in an emergency. Through snow and flood waters unfortunately, in my 182.
The car was absolutely fine and had no problems after. I was very careful.
It had been parked up for about 10 days and now has a loud scraping noise and what sounds like a worn wheel bearing from the front end (low grinding noise and scraping). I pulled up as soon as I heard it.
I'm thinking it can't be a damaged wheel bearing because that's usually progressive over time and doesn't exhibit scraping noises usually. Perhaps there's dirt which needs removing from the drive shaft etc? Has anyone any good ideas about where to look when I remove the front wheels later? I know, I'll probably end up taking it to the garage to be sure nothing's seriously wrong.
Adam
Adam
