I'm guessing that it must have a hole in it, although not sure. Whatever it is water and wash dont last very long. Are they a big job to remove and refit?? Can't think what else could cause it tbh. Gutted as not even had the 2 a week
headlamp washers dont appear to leak. But also I've not used them. The water is running down under the car behind the front wheel. Which makes me think bottle
just refilled tank. Its leaking also under car in rte middle. Coming out where the undertray is. Headlamp washers dont come on when normal washers do. So could that be the problem. The tank was empty when I got the car. So suspect it was like it when I got it
hey i just had this problem with my 1.2, as soon as i filled it up i travelled about 5 mins and it was empty took to garage and it was my thermosat housing and seal leak! sounds very similar but might not be the case, still just need to get it checked. hope i help, not very technical wen it comes to problems.
