Serious hesitation/kangarooing 1.2
Car  2007 clio dynamique
Hi basically its as the title reads if you try and accelerate it just doesnt move and then after a while it will accelerate but not very well and kangaroo , it feels like its been starved of fuel its fine though in nuetral when not under load any help would be great thanks
Happened since the bad weather? Had a 08 plate 1.2 wouldn't start and when it did misfired, the coilpack was Covered in water, just something to check, otherwise get your fault codes read as it could be either lambda or coilpack/leads/plugs etc
Thanks for the reply , its been an ongoing thing , its basically a project car and its been the same since i got it , theres no popping etc that you would expect from a misfire , if you press the accelerator lightly it will pick up speed but its when you try and drive it normally it just wont go
