SERV light, but no fault code?
DaveDreads
Yesterday my SERV light came on, Ive plugged my RST Box
in to the car but no fault codes stored?
I did a search and it's been mentioned that it could be a low fluid level
somewhere, but all fluids are fine.
Could it be that my washer jets aren't working?
Common on clios.
Under the passenger seat there is some wires, wiggle them and make sure there plugged in.
Then test
maynard
  ph2 172 track car
have you checked your oil? this happened with my mates 172, just SERV light and nothing else. checked dipstick and it needed topping up. light went straight off when he did that. worth a look at the dipstick imo.
what are your brake pads like? if they are low this will come up as low fluid - but the handbrake light would be on too..
DaveDreads
Brake pads are brand new, only been on a month or so.
I'll check the oil, I guess that the oil OK message on my trip
computer can't be trusted.
  Mk2 1.2 Campus
The RS tuner boxes don't do full diagnostics, only engine related. Need it on a clip or similar to tell for sure
