Service and airbag light
Car  dci 80
I disconnected my battery to change my seats as I thought I would be safe with the airbags in them but now I have a service and airbag light on!
How do I reset them?
Cheers mike
Then you've either not plugged them in correctly or the components in the seats you've fitted are fekkered.
Is there any way I can change the pre tenshionors off my old seats to my sport ones to see if that's the problem? Or what else could I do?
Cheers mike
Yep, you can swap the lot and the pre-tensioners are an easy DIY job with the seats out and next to each other. If its the seat bags at fault though you will have to de-contruct the seat coverings which isn't hard but can be tricky to get back right.
If after all the swapping the light is still on then its most likely you've damaged something else whilst doing the swap like the side impact sensors which lives in the sill areas.
Mick
On closer inspection it looks like the passenger pre-tensioner has gone off as the seatbelt anchor has been pulled right in so I'm just glad I've found the problem it just means taking it back out to replace the pre-tensioner!
Cheers mike
