Service light reset
04-182
  AB Clio 182
Hi. I’ve had a quick search but couldn’t find a post. How do you reset the service light on a 182 please? No other lights on dash and reader says no detected faults so I’m assuming it’s general service due indication.
Engine oil, gearbox oil, filters, coolant all changed last year.
Thanks in advance.
Louis
I Love Ed Sheeran
Thanks in advance.
It's not service related, it's a fault
Brigsy
  T.Turbo
Need can clip on it to read the faults properly, probably airbag related
04-182
  AB Clio 182
Good chance. It came on after I turned the passenger airbag light off for jr in the front but stayed on after it switched it back on and subsequent starts.
04-182
  AB Clio 182
That's working then.
Service and airbag light on now regardless of switch position. Will investigate further. Have a spare switch so may swap that over and check the connections under seat aswell as moved then getting kids in.
04-182
  AB Clio 182
sorted. wiring under passenger. previous owner wonder wiring. now sorted.
