service question
Car  clio 182
hi guys. going to replace my spark plugs and ht leads. iv read that you need to remove the plenum to get to them and then replace the gasket correct?? any ideas how much and where to get a replacement gasket, is renault the easiest option? also going to do a oil and filter change, is removing the fuel rail guard the easiest way to get at the filter?
cheers guys
Yes, remove the plenum, pretty simple job. The gasket is aprox £9 from renault so there is probably the best option. I always remove the rail guard just because i Have hands like spades but you can do it without. After all its only 2 nuts :)
Theres a guide in the guides section on how to remove it. WHen putting back together do not do the plenum bolts up too tight.
