Servicing Data
  Clio 172
Afternoon Gents,
I've bought some bits and pieces for Servcing. Anyone know what;
1. The Spark Plug gap is
2. Amount of oil the engine takes
Also, I'm picking up a pollen filter this afternoon - where the hell does it go!?!?
And do I need to change the sump bolt when I've removed it?
Alex
New sparks will come with the gap correct. No adjusting needed as I know off
Amount of oil is 5.1L (including oil filter change)
Pollen filter will go where the scuttle board below the windscreen is removable most easy. (drivers side) You'll have to remove a plastic cover there and exchange the filters.
BTW there are some guides about this in the guides section.
