As title, if I press pedal in a couple times slowly revs will move a bit, if I repeatedly press it fast the revs go above 2k
When cars off the pedal has a lot of travel, you can pump it up and it will be firm but theres always 2 stages of travel, a complete dead zone as if the push rod isnt engaging the mc then a spongy feeling, then the firmness
Car is now running an abs delete with a bigger 4 port mc (for brembos), have pressure bleed the system and no air is coming through
Also there is a click around half way pedal travel when the cars off coming from the pedal area, not when the cars on
Tia
Tia
