shift light/rev limiter....
Car  200bhp itb'd iceberg
hi all have a quick question
when i drive my car from cold i wait for the car to warm up before i give it some but when i do the shift light comes on early at 6500rpm and it limits at 6900rpm but if i turn the car off an start again it will be fine
any one have same problem?
Ive only recently been informed that the little gearstick light shouldnt really be considered a "change" light.. its more of a "your raping me so use another gear please" light!
Warming a car up takes aleast 10-15 mins if not longer, i think the optimum temp for oil is like 80 degrees. Maybe its not completly warm when your givin it the beans?
the rev increase after the coolant has reached a certain temp:
<75 deg C = 6700rpm
> 75 deg C = 7200 rpm in 1st and 2nd gear
>75 deg C = 7000 rpm for 3rd 4th and 5th
Its not off oil temp.
The light comes on 300 rpm below the maximum rpm in that gear depending on temp
Whats the difference between a shift light and a light telling you to shift gears??
Zero, nothing, its the same thing but a glossed over name
