Shocks Absorber Strut
Car  Clio 1.2 TCE
Hi Guys,
Quick question...
Recently having trouble while driving over uneven surfaces, the car on the passenger side would vibrate quite loud.
Had a good look at the Passenger side suspension, the Drop links and lower suspension arm have recently been replaced, i decided to remove the Shock Absorber strut and dissemble the Spring from the Shock Absorber. After doing this i have noticed that once the Piston on the Shock absorber is pressed in, the piston will not return to its position.. The piston does not depress.
Is this Normal? Should the piston return to its position?
Any advice would be great,
Thanks,
