spot on. ill have to take a look. bout £30 for both ish yeah
do they give you those coloured caps free?
its something like 520mm x 84mm. Ive had about 12 pms about the plate lol
mines were from fancy plates. i just got a standard plain rear plate
On fancyplates.com did you choose "Fancy plates" or "Standard UK Plate"?
I want some like yours, but dont want the companys postcode in the corner like standard plates are meant to have
Paul,
how come youve attached your fronts with pads and the rears with screws?
and which pads did you use? just the standard adhesive ones from somewhere like halfrauds?
i thought you must of done cuz ive used them in the past and there shocking. cheers
Paul B - am i right in thinking your front plate falls a little short of the recess? Would a 90mm or so height be better than the 84 is states in the guide?
Is the recess the same size on a Ph1?
