Side mounts for buckets
not sure tbh mate
im using sparco sidemounts with omp subframes if that helps? :clown:
do you mean to bolt to existing seat runners?
you cant go wrong in terms of bolt hole locations as the sidemounts will have numerous holes to line up, its more the width i'd be worried about (ie distance between the sidemounts when attached to the seat)
some sort of subframe, some have them custom made, also depends if you want runners?
mine are fixed in position to the omp subframes
