Use a flat blade screwdriver. Its easy peasy - there are two small holes each side of the lens, which you stick your screwdriver in to release the lens.
and remember its illegal to leave the white bulbs in, u should replace the bulbs with the orange ones that should have come with ur set. But then again ive had the white bulbs in for ages now and the old bill still aint pulled me over! Oh ya thats another thing, will I pass my MOT with white bulbs?
Philips Silver Vision Indicator bulbs.....The special silver finish puts an end to that fried egg look through clear indicators, bulb is orange when lit. Can be modified to fit most cars.....(10 minutes with a small file!!! )
Just fitted some clear side repeaters...did exactly as you said Thanx Ben. Look great!!!!!!! the fitting took 5mins, as you said, but the realisation that I had to cut off a bit of plastic from them took a bit longer..."dont need to do anything to the car" they said at the shop...forgot to mention the Clio spercific repeaters needed chopping....Doh!! next time Ill know to ask about the part as well as the car!!!!!!!!
