Sidelight bulb not working
Car  I love Lamp
I just tried switching to LED sidelights and got the passenger side in fine and worked, tried it on the drivers side and came out fine, put led in, was bit awkward but then went in easily once I got my other hand in but that one wouldn't come on, thought I'd try putting the old one back in to try it but that one wouldn't work either. What have I done? :( could it just need a wiggle or could something have come loose?
It's dark now so will look more in the morning.
Cheers for any help :(
LED sidelights only work when put in one way. Check the fuses. Does the drivers side rear sidelight work? If not, the fuse has gone.
It's a SMD Led but no I only tried it one way but then the old bulb also didn't work when I put that back in which was a standard yellow thingy. The rear sidelights work fine, I'll check the wiring tomorrow and try turning it around, see what I can see in the light I guess. Cheers
